vcToolFrame
Tool frame object
Module: vcRobotics
Parent: vcBaseFrame
Referenced by: vcRobotController.Tools, vcToolContainer.Tools
| CenterOfGravity | vcMatrix | RW | Defines the mass center point of payload and if needed the orientation for LoadInertia. |
| Inertia | vcVector | RW | Defines the inertia value (kgm^2) for each axis defined by LoadCenterOfGravity. |
| Mass | Real | RW | Defines the weight (kg) of payload. |
| delete | None | None | Removes the base from container. |
